What Kind Of Footprint
  • Thread starter Thread starter Weaserlorian
W
Weaserlorian
I ment to post this a while back.
I went for a quad ride and always take tackle and a fishing rod with me. I stopped to throw a line in on one of the lakes I was passing along the way.
I came across this rock on the shore. No can tell me this is not a actual foot print, but of what? It has to be very old even ancient.
It's just odd because this is Cold Northern Canada . The most people find around here is the odd ancient Aboriginal tool.
Anyways I thought I would put this out there for our members to see.
It's a footprint of Trudeau's ancestors.
It doesn't look like a footprint to me, but then again I'm not a geologist or a paleontologist , but I do play one on TV. It could be just pareidolia messing with your mind ?
Canada was once a sub tropical area, I know they have found footprints in Alaska, here is one down below that looks similar to the one you found, maybe the one you found is a handprint ???
u-https-canadajournal-net-wp-content-uploads-2014-07-Researchers-Discover-Thousands-of-Dinosaur-F.jpg
Looks like it's giving us the finger and I am highly offended. :mad:
If you documented the exact location with your iphone, you can return with a measuring tool and photograph it showing the dimensions. Then you could contact one of the Canadian paleontology museums or related university departments to inquire.
I know exactly where is. I might just do the measurement thing as you suggested and take you advise about contact someone down south.
Thank you!
Do you know what kind of rock houses the print? I can't tell much from the photo, although the surrounding rocks suggest shale. If you take a series of photos illustrating the immediate site, it will provide good clues to the fossil's age and the maker's identity.
I wouldn't mind finding something like that, I'd be hunting down some of that rubbery stuff that you mixed and it cures in a fairly fast time and make a perfect cast. Then you could have it as a decoration for the house without damaging the print and might give you a better idea of what made it.
"Liquid rubber casting", there's a variety of products, find one that won't do any damage.
