Recommended Nighthawk Replacement
trampy
USA
Recently my Nighthawk R7350 died and looking for recommendations for replacement that people have used and are happy with.
Need it to cover 3000 sqft home
Able to handle 50 + devices (many only top 25)
Not breaking the bank (250.00 or less)
Thanks for any recommendations.
https://www.amazon.com/ASUS-RT-BE86U-Dual-Band-Subscription-Free-Comprehensive/dp/B0DGZZJ996?tag=bngsmtphsnus-20&linkCode=df0&hvadid=80814293607860&hvnetw=s&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=110593&hvtargid=pla-4584413768038639&th=1
I am rocking the BE9300 - Nighthawk WiFi 7 Tri-Band. Had it about a month or so. So far so good. 2.5GB ports and good coverage.
Moved to General.
Not an actual tech support question.
If you're willing to make the investment, you'll find a HUGE online community of Unifi fans. Their gear is MUCH higher quality than standard consumer-grade equipment. But be forewarned: once you buy one item, it becomes an addiction after you see how well all their devices play nicely with each other. And the remote accessibility / control is unmatched. But be sure to purchase either directly or from an authorized reseller (i.e. all the Unifi gear you see on Amazon is marked up and NOT sold by authorized resellers). I've bought both directly and from B&H and highly recommend both.
