That's why in the summer it was a surprise to see reports flooding in from Verizon customers alleging they could no longer access a number of pirate sites including MangaDex, NYAA and Kemono.party.
These sites have a few things in common. They all operate in the manga niche, they all have issues with copyright holders, and they all use (or have used) DDoS-Guard, a Russian CDN provider that's considered a safe haven for pirate sites.
That raised the question of whether the nature of the sites themselves was behind Verizon's decision to block (or more accurately, null-route), or whether the use of DDoS-Guard was the key factor.
Verizon Fails to Unblock MangaDex
With Verizon failing to fix or even acknowledge the issues, subscribers of the ISP have not been able to access MangaDex by ordinary means. VPNs still worked, of course, but as the image of MangaDex's network map shows, when Verizon interferes with user connections to DDoS-Guard (the straight line pointing down from 'Users'), none of the infrastructure behind it can be accessed.
Of course, MangaDex could've told Verizon subscribers to use a VPN or even cast them aside completely. However, that clearly isn't the platform's style. Finding some way to bypass Verizon's blocking appears to have become a challenge so, over the past several months, the team has been working on it.
MangaDex Nullifies Verizon's Null-Route
In a recent announcement, MangaDex revealed that its team has been successful. How they achieved this is being kept a secret for now but the site confirms that its solution works and they received zero help from Verizon.
"To eliminate some misinformation we've seen circulate, we would very much like to not thank [Verizon] as they didn't lift the ban on their end to this day. However, we are really glad to have found a workaround and happy to welcome their users back on the platform," the team writes.
While this will be a cause for celebration for some Verizon users, MangaDex says that it doesn't know if the fix will be a permanent one. The best solution, then, would be to switch to an ISP that doesn't quietly block sites and then offer no explanation.
"We also must mention that there is absolutely no guarantee that our current workaround will last forever, so you might want to consider switching to an ISP that doesn't censor your internet access at some point. That means pretty much any other one in the world," the team concludes.
The above image is courtesy of MangaDex which recently published an intriguing overview of its operations
