I was wondering as I am sure many others are.
malaki
Not sure, it's dark outside
Is it lack of so called pollution that is triggering this heat wave. I do know from readings that lack of carbon in the air is affecting trees that rely on this for life, and turn it into oxygen that we all need.
Now the Sun's rays can beam down upon us unimpeded, no filters for that heat. Maybe we were intended to burn coal and use oil in our cars?
Just a thought. Perhaps you have other thoughts?
Well I must say and just an opinion from a regular Joe.
Our world is heating up due to pollution.
It is not gonna get better but we can slow it down.
I will never see the results of this as I am in my 60s but our children and grand children will have to live with this.
Will there be a fix, I highly doubt it as the powers that be want to make money.
At some point the world will redo what we have done to her and people will not be part of the plan IMO.
Live each day as it was your last and try to make a difference.
It will only get better when we stop using fossil fuels. Some governments are banning the new sales of pleasure gas vehicles by 2035.
Aeroplanes have a direct interaction with the weather because of the con trails being ice, that ice forms clouds, clouds form rain....I'm sure you get the logic. When we had a very limited amount of aeroplanes overhead during the first lockdown, weather was gorgeous, plus most factories were closed as well. There are other issues, the earth wobbles on its axis, this wobble throws the weather out, waves and a whole host of other issues. Next, most people believe the sahara was caused by global warming, in a way they are correct but it isn't man made.....it is because the earth tipped on its axis and that over time has caused the sahara desert.
Due to the over use of concrete, this also causes the world to be unbalanced because of the weight, now you might think that's nonsense but it has been proven to contribute to the tipping. China have well and truly over used concrete, and you can see this from all the roads, housing estates built and not being used.
Volcanic activity is also changing the weather, as to does the moon. The biggest issue is the rain forests, cut down for gold, palm oil and soy for the animal feed...this causes a chain reaction in the weather as well. There is no, one main contributor to the weather....even cows produce more methane than humans collectively....this has also been proven.
Oh and the gulf stream causes problems too, sometimes it reverses, sometimes its weaker than other times.....
What ever people do for good or for bad, there are sure to be others that disagree, just accept that you have one life and that is in your hands. (or should be?)
