Check and adjust your display monitor
Katzenfreund
The Oracle
Europe
As you are sitting in front of your monitor for long hours looking at fine print, images and videos, you'll want its picture quality to be at its best. It doesn't cost anything to get it as good as possible.
Is your screen too bright with the result that, in addition to wasting energy and causing eye strain, bright details are also washed out? And what about contrast, definition, gamma and color balance? Do not assume that the display is correctly set at the factory.
The specially designed images on this website will reveal all picture flaws, with suggestions on how to correct them.
http://www.lagom.nl/lcd-test/
If you have samsung screens, you get the software to adjust not just the vertical and horizontal etc but you can move the screen according to where you are sitting, without moving the actual screen casing.
